Spec 3+
The 3+ falls in the middle of felling like a stock clutch and an ultra-fast on/off type clutch. When people say on/off, they mean the clutch is like a toggle switch, its either engaged or disengaged with no modulation possible in the middle. The 3+ becomes easy to drive after it breaks in but you will drive it just a bit differently than a stock clutch. On/off clutches are no fun to drive on the street.
The whole release point of the 3+ occurs in a very small window of pedal travel as opposed to a much larger window with stock. This is due to the full face, NON marcel sprung hub used in the 3+ disk. NON marcel spring hub disks provide better grip at the expense of some smoothness, engagement speed and chatter. My 3+ has very little chatter on take off and what little is there, is eliminated by revving the motor just a tad higher before taking off. I have actually driven stock clutches that have morre chatter than a 3+.
Because of how fast the 3+ engages, I installed a pedal limiter on my clutch. I did this because the point of pedal travel at mid point all the way to the floor is entirely dead and serves no purpose. There is no clutch disk engagement at all taking place in this area.
Most higher performance disks, especially if they dont use a marcel spring, behave like this.
EDIT:
The overall drive-ability of the 3+, IMHO, is very very good for a high performance clutch. I never experience any jerking or significant funky ill effects you tend to see with HP clutches. Hell if my wife can still drive it, then it must be good. Is it just like stock, no it is very close.
However some will agree with your statement if you are referring to the standard Spec stage 3 clutch.
my clutch before the 3+ was the 3 and it was a freak. held 800ft/lbs and never slipped once. 300 shot out of the hole at the track and held up to 1.40 60's all day.
If you are going to be drag racing, and want repeatable performance without compromise, the puck style is the way to go. With the new formulation on the Monster clutches, they have great street manors too.
