Spec 3+
I love mine..
Edit...even better
heres your 500 dollar option...do a LS7 clutch and be done with it....plenty of guys making 550rwhp with their ls7s with no issues...its those drag racing with 550rwhp and the ls7 clutch that have issues hell stock ls7s drag racing have to really finesse it
Edit...even better
I was one of the first to put the LS7 clutch in an LS1. My 346 made 460RWHP and I loved the LS7 clutch. My 403 makes so much more grunt and I like to play with it I don't think the LS7 would last too long. I agree the with the full face disc which is why I'm pretty settled on the 3+. Peter Pan runs one with 770RWHP and loves it.
Source, I am not sure what twins you are referencing but our stage 3+ and Super-Twin offerings are extremely drivable. They were built to provide the best of both worlds and subsequently are fantastic on street or track. If you have any questions about our offerings you are welcome to contact me at any time. Thanks!
Its as aggressive with the clamping force but street manners it doesn't compare at all. I have the spec 3+ and would take it all day over my buddys twin disc in his ws6 that is already slipping with less miles on it than my spec.
Mine had very good grip early on but clearly it has softened up after about 5K miles or so. It now wont grab third gear any longer like it used to. I recently replaced the TOB and saw that the disk has worn a measurable amount of surface off of the pressure plate and flywheel probaly to the tune of .030" each. The disk showed little wear.
wrd, where is the engagement point for your clutch relative to pedal travel (high or low)?
I've got around 5k on mine & it's still awesome. Just pulled & looked @ it while freshening the shortblock. Mine showed minimal wear on the PP & flywheel; maybe .001"-.005" & even that appeared to be just break-in wear (.000" in on place & .001"-.005" in another). Should also mention that I try to rev match & am careful not to slip it.
Do you have the shim installed? Do you use an adjustable master? An adjustable master w/ no shim can be used. Although, there is measurement required on the initial set-up to ensure that it can be installed without the shim. Regardless, if she's slipping & worn now, removing the shim may help, as long as there's enough slave cylinder travel to dissengage the clutch.
Might be exagertaing a bit t .030". Its easy to see and feel which means its more than just a few fractions. It installed right. Not sure how one can frig up a clutch unless the friction surface got contaminated with grease. I also babied it for 500 miles. One more thing, I am a "red headed LT1 step child" so not fancy master or cylinder was needed.
Clutch release point is very high on the pedal. No way to adjust it on LT1 hydros.
For daily driving and playing on the street it is good. But with stickies and strip use, I guarantee it has very minor slip that it did not have earlier in its life.
