Longer 5th gear ratio
Old 12-28-2009 | 01:21 AM
FreakChevy's Avatar
Default Longer 5th gear ratio
Hey guys
A friend has 01 LS1 Camaro built engine plus TT...The car will be for highway pulling.
We need longer 5th gear!
What should i do ?
Old 12-28-2009 | 10:38 AM
thesource's Avatar
Play with the diff ratio or tire size. There is not any way to adjust the 5th gear ratio on the unit.
Old 12-29-2009 | 12:21 AM
N20zuki's Avatar
shift into 6th?
Old 12-29-2009 | 02:12 AM
FreakChevy's Avatar
no one offer 5th gear set with higher ration?
Old 12-29-2009 | 12:04 PM
BlackScreaminMachine's Avatar
Internet Mechanic
The diff ratio I have seen is "Shorter", I would contact companies that service all T-56's trans see if there is a comprimise. IMO like said, play with tire sizes. Also should help with the extra sidewall.
Old 12-29-2009 | 03:32 PM
RacingTiger03's Avatar
as far as it bolting up to the LS1, I'm sure there is some way to do it... but what came to my mind is the old T-56 produced by borg warner for the early LT1's. It had a very tall 5th and 6th gear ratio and slightly deeper 1-4th gears. If not the whole transmission, surely some company out there makes that gearset. IIRC it was 0.86 and 0.51, but it has been a very long time since I looked into it. I am positive of the 6th gear ratio, but am not on the 5th ratio.
Quick Reply: Longer 5th gear ratio
