LS6 Clutch?
Old Dec 28, 2009 | 12:57 AM
aerojt's Avatar
Default LS6 Clutch?
I live right by Summit and was interested in the LS7 Clutch kit for my rebuild this summer. I found this one though, anybody buy this or put it in or have any experience? Seems like a good buy and clutch for my daily driver that isn't going to be taken to the track or anything.
http://www.summitracing.com/parts/NA...6/?image=large
Thanks for the input.
Old Dec 28, 2009 | 08:27 AM
teke184's Avatar
for a bolton car, the ls6 is a good option. holds teh power and drives like stock.
the ls7 is much heavier..and in many cases overkill.
Old Dec 28, 2009 | 01:56 PM
aerojt's Avatar
Well thats good to know. Any other opinions? Anybody have this clutch?
Whats the difference between this and my stock clutch?
Old Dec 28, 2009 | 05:07 PM
CoastieWS6's Avatar
If I were you I would get what I got. The LS7 clutch with aluminum flywheel. I payed $570 for the kit and included ARP bolts. I bought it from the ws6 store. Also the LS7 clutch isn't that heavy, it's the LS2 flywheel. That's why I went with the aluminum flywheel.
http://www.ws6project.com/user_stor/...a9f832a5f14ce4
Old Dec 28, 2009 | 05:21 PM
TAtoad's Avatar
Well what vehicle do you drive? I believe 02 ls1s came with an ls6 clutch. im at 61k and its time for a new one. i'd go with the ls7/ls2 combo, thats what im looking into
Old Dec 28, 2009 | 05:39 PM
CRAGER's Avatar
Administrator
01-02's came with LS6 clutches. They're junk, they can't hold bolt-on power. Why put another junk one in?
LS7 clutch is far far far from overkill, plus there really is NO such thing as an overkill. Maybe a McLeod twin-disc in a v6 f-body, then sure that's an overkill.
Just stay away from LS6 and get LS7. Drives like stock and holds way more power.
~ Craig
Old Dec 28, 2009 | 06:55 PM
RsSean's Avatar
I have the LS6 clutch now in my car, I like but I am going to step the HP a lil and it will not hold it. Like said above for a bolt on works good adn it gets the job done. You should check out Monster Clutches that is what I am going to when it gets to my door.
Holds 450rwhp very well so you have some what of a idea of power it is holding.
Old Dec 28, 2009 | 08:13 PM
71novaguy's Avatar
Did not know that. Mine faded out around 54k. I thought I would have got more life out of it.
Old Dec 28, 2009 | 08:14 PM
NVR_SPDS's Avatar
Id skip the LS6, and get the LS7 atleast. Like was said, the 01-02 LS1s had the LS6 stock (Our 02 WS.6 had it) and its not the strongest clutch out there.
