Got problem with clutch when launching hard.
Old Dec 17, 2003 | 10:27 PM
1320_PERFORMANCE's Avatar
Default Got problem with clutch when launching hard.
Wassup guys, I need help! When I launch MY car @ about 3k to 4k and I engage my clutch pedal to shift to second and it has no pressure and end up grinding second and a strong burnt clucth smell follows after. Is it my pressure plate? or slave? do i need to do the drill mod? I got a 2002 z-28 stock clutch, mods below and got 10k miles on car. Im gonna be replacing my clutch, Im going with the spec stage 3 x-pad, Is there anything else that I need to purchase or do when installing my clutch. Ill probly use my stock flywheel and jus resurface it since i got low miles. Any advise would be great . THanks in advanced.
Mark
Old Dec 17, 2003 | 10:34 PM
Slowhawk's Avatar
LS1Tech Sponsor
The clutch is slipping in first gear,causing the hydrolics to boil,meaning it wont disengage the clutch enough to pull second...My stock clutch lasted 5k miles due to the track.
Old Dec 21, 2003 | 03:11 PM
jerflash's Avatar
my clutch does the same thing when i pull low 1.8s on the nittos
the clutch spun so hard in first that it did not let me in to second at all it would not even grind haha
Old Dec 21, 2003 | 07:17 PM
wrencher's Avatar
wrencher
Yep it's clutch time.
Sounds like your powering thru the clutch a little.
Old Dec 21, 2003 | 09:40 PM
Thanks guys, Where is the best place to purchase spec stage 3 with the new x-pad? Do I have to change anything in my hydrailic system, slave, master, etc. Thanks in advanced.
Mark
Old Dec 21, 2003 | 09:43 PM
jerflash's Avatar
no if you have a 2002 you are good to go
Old Dec 22, 2003 | 04:08 PM
pontiac's Avatar
i have a spec and you cant make it slep. Shift out of 3rd at 3500 and snap forth and she'll chirp hard. holds up to et steets as well
Old Dec 25, 2003 | 02:50 AM
The LT1 That Could's Avatar
call up TSP....i read on this board they are have a special on clutches...not sure if it is still going on tho.
check my sig for their link!
Old Dec 26, 2003 | 06:25 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Make sure you bleed the system and replace the DOT 3 with DOT 5 racing fluid!
Old Dec 26, 2003 | 06:31 PM
jerflash's Avatar
hey man my last name is rizzo hahaha
Old Dec 26, 2003 | 06:59 PM
Good for you tough guy!
Nice ride!
Old Dec 27, 2003 | 12:33 AM
jerflash's Avatar
thanks man nice ride yourself i wish my car could do what you can could do
HMMM SOON
Old Dec 27, 2003 | 10:06 AM
thechef's Avatar
Moderator
call us at East Side Performance 1-203-269-1539 we have great prices on the spec 3 xpad
Old Dec 27, 2003 | 04:23 PM
silkey's Avatar
all i can say is ,my spec3 lasted for 30 runs at the track.it was installed at mti,so its either its a sorry product or a poor instalation. i have a 2002ws6.
Old Dec 27, 2003 | 06:07 PM
shkettle's Avatar
hi guys
Old Dec 27, 2003 | 07:24 PM
Do I really need to changed my flywheel? got 10 k on my car.
Old Dec 27, 2003 | 11:13 PM
ESP101's Avatar
i would change the hole assembly get it all balanced together ang start fresh if interested give me a call 203 619 4732 thanks guy
Old Jan 9, 2004 | 02:47 PM
07BlueDevilZ06's Avatar
we will beat any price you get we are the spec dealer of choice hands down
Old Jan 11, 2004 | 08:26 AM
silkey's Avatar
do the drill mod
