clutch help
There is also a shim that spec supplies that goes behind the slave, I have had to use it on all but one car so I would use it if they give you one..
Shim???
I didnt' get No shim
My Spec works Great.
. at least i got the clutch disk lined up pretty good inside there. im done for the friggin day
If you are doing a C5 clutch its kind of a pain, if you are doing an f-body it shouldnt be too bad since everything is pretty much out in the open..
with the gears
