All T56's Created Equal?
Old 02-06-2010 | 07:55 PM
Z33Art's Avatar
How does the viperspec transmission differ from the LS1/LT1 transmissions pictured above? (If at all)
Old 02-06-2010 | 08:39 PM
85MikeTPI's Avatar
A viper "spec" trans is just a standard transmission (LT1, LS1, etc.) with a viper mainshaft. (shortened and tailhousing machined larger)
A real viper spec has a longer tailhousing, and it's slave cylinder bolt holes are clocked differently than the LS1 Fbody.
Slave bolt holes at 2 and 8 o'clock
Old 01-05-2011 | 06:49 PM
Stang's Bane's Avatar
Besides the tailshaft, what is different externally between the vette and gto/f-body ones?
Mounting holes for the slave cylinder? Thanks
Old 01-05-2011 | 07:12 PM
85MikeTPI's Avatar
The vette front plate has no provisions for a slave, it mounts to the torque-tube and remote shifter linkage.. It can't bolt behind an engine without changing the front plate, adding rear shifter linkage, and tailhousing/mainshaft/etc..
Quick Reply: All T56's Created Equal?
