Dunno wat clutch to buy
So ive been looking for a new clutch kit to buy but em unsure of what to get. I know its time for a new one, im not sliping gears or anything but i hear ratteling under there and well anyways was going to replace it. Also gonna do a rebuild as well.
Well my real question is. Anyone have any info on whats good and whats bad out there, Whats cheap and whats smart to get. I see alot of people buying LS6 clutches but i kinda want a new clutch and don't want to pay an arm or a leg since this is my DD and im not trying to make it a beast. just enough to kill stock 09 vetts.
So whats do you guys recommend i get.. Im looking to spend around 6-700 and im looking to get everything. Flywheel,TB, the whole kit to pull off a swap.Thank you for the help.
The Diamond Stage 1 would suit your needs perfectly, as its stronger than the LS7 clutch. The kit comes with a new slave w/ TOB, pilot bearing, & new chromoly lightweight billet flywheel. Or if you wanted something a step up, the Stage 2 would be fine as well. Its right in your price range at $599-649 on special until Jan 5th. Shipping is just 20bux too. Both setups are very streetable and drive almost like stock. The Stage 1 is rated at 500rw and Stage 2 is 600rw. Check out this link for the special
https://ls1tech.com/forums/manual-tr...s-special.html
I helped a buddy install a Diamond stage-1 over Christmas vacation and it's a very, very nice piece. Well built, perfectly smooth balance job from idle to 6K+ RPMs, no chatter.
It may be significantly lighter than the LS6 clutch/flywheel it replaced, the guy says the engine revs quicker. Maybe TDP can comment on their flywheel weight as compared to GM's LS6.
