Clutch Bleeding Help
Old Dec 23, 2003 | 06:05 PM
LT1TECH2003's Avatar
Default Clutch Bleeding Help
I Have Pressure Bleeder With A Mac Pressure Bleeder, Used The Mitty Vac Method, Pushed Fluid From The Bleeder Up To The Resivior, Tried The Traditional Way Pump And Crack The Bleeder, I Tried The Crack The Bleeder And Push The Pedal Down Method, None Of Them Worked....all I Did Was Take A Spec Iii Clutch Out And Put A Stock Clutch With A New Slave And Thats It... It Worked Fine Before I Pulled The Clutch And I Have Also Put Another Slave Also...
