SSR Fbody T56 hybrid project (1000hp on stock parts?)
#101
Nope. Even after the machining, the thickness of the yoke walls were just as thick as the Viper or Ford 31-spline, so I didn't really see any point in using the SSR tailhousing/bushing. It's not a big deal for me to get it machined anyway.
#102
Yeah, I wasn't calling you out or anything, was just curious. No machine work is a big deal for me either, I can do anything like that on my own...in my case though, I picked up an SSR tail housing, which I need to mill down to the right shifter height, but then I'll be running an SSR 40 tooth VSS wheel (easy to re-program for) and an unmodified chromoly slip yoke...I've twisted a few regular yokes on launch in a heavy car on slicks, granted, they were smaller yokes for a 27 spline shaft, but the price of the chromoly one isn't a big deal to me, and it's a little more piece of mind...I'm hoping my little 370 makes some serious power, and I'm hoping my slicks stick like glue...so I need less other stuff to worry about when I let the left pedal fly
#103
I finished the 32-spline build a few weeks ago. Just been too busy to post about it. That modified mainshaft worked out great, btw. Remember I had the 2nd gear journal modified to accept the stock 1-2 snap ring. Other than that, I broke the CTS-V speedo gear trying to install it onto the splines. I even heated it up quite a bit with a heat gun. Ended up getting a stock 27-spline speedo gear milled out to 1.371in and it couldn't have been a better fit. I ended up using an 8in 1350 TH400 yoke. I got it cut down to 6.5in, and of course had the o.d. cut down to the proper size.
I take it you're using the 30-spline bored viper-spec fbody tail and turning down the 32-spline yoke. I just finished one of those also.
#104
The CTSv wheel needs honed out also, it's not a direct fit. (I use a brake cyl hone to open it up 0.010"). It's an easier starting point than the Fbody as most people won't have an easy access to a mill compared to a hone.
Yes, I used the Dodge bushing, and had the yoke turned down to the same o.d. as the Viper 30/ Ford 31. We ended up using a GM style 1350 yoke since my customer was having a custom driveshaft made anyway. Might as well go with the 1350, instead of the 3R--->1330 conversion u-joint.
Now that I think about it, there should be a bushing available that's smaller than the SSR/TH400, and larger than the Dodge bushing. This way we could still use the f-body tailhousing and have a larger bushing/yoke combo, since the yoke can be machined down to any size in between the two. I'll have to pilfer around the bushing isle at my local Tremec dealer and see what I can come up with for the next 32-spline build .
At the end of the day, it probably isn't going to make much of a difference as far as strength goes, but it's just something different in a good way.
#105
#107
Well...as an update. GM has 32 spline mainshafts in stock still (and his voice didn't show any "this part will be gone soon" type of tone), and The Gear Box just e-mailed me saying 1 new shaft came in for their inventory, and another Tremec supplier (a local shop) just e-mailed to let me know they're in stock and available for order from Tremec.
I've got one on order from GM right now and I'm going to order another (as a spare) from the local guy later on today once he gets back to me with a price...and then a few other parts from The Gear Box...since everyone has been so friendly with helping me track the part down, I want to make sure I buy stuff from all of them lol.
#113
Does this trans only work with LSx engines and transmissions or will it work with LTx engines as well since I know the input shaft length is different between the two?
I have a 94 Z28 with a freshly built engine which will be running N20 and I want a stronger trans, thanks.
#117
I believe the Chrysler (correct 26 spline; full o.d. which can be resplined) input with the 31 tooth 4th gear could be used for a double/single synchro MM6 LT1 build.
Not sure if there's a 29 tooth Chrysler double cone input for an MN12 LT1 build. I better go back and make sure Mike didn't already tell me this was a no-go in the past.
#118
IIRC, the LS1 input is a smaller o.d. behind the splines than the major dia. of the splines.
The LS1-type double-cone input wouldn't be able to be re-splinned, it would have to be cut behind the splines and rewelded. Jason@TDP offers this for $100 IIRC..
#119
Latest two examples of configuration options for the DIY'er:
C5 Vette Base MM6 donor with 32-spline mainshaft and F-body Viper tail-yoke
C5 Vette Base MM6 donor with 32-spline mainshaft and new 1pc C6Z06 countershaft
#120
C5 Vette Base MM6 donor with 32-spline mainshaft and F-body Viper tail&yoke
