Eye Candy...faceplated T56
Well guys, I know it has been awhile since I have been on the Forum answering tech threads, but all the PM's I get keeps me PLENTY busy, haha!!
Anyways, we don't get to many faceplated trannies, so now that the shop is in teh middle of one, wanted to post up some pics for you guys. Enjoy:
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1591.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1582.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1583.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1584.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1586.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1588.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1589.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1596.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1609.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1611.jpg)
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1615.jpg)
Got tranny?![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Got tranny?
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1616.jpg)
Sure can.
Basically, here is a picture of a stock setup (synchronizers):
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN0979.jpg)
See all teh "little teeth"? When you shift gears, ALL of those teeth have to "slide home" into their "little slots".
Now, take a look at a faceplated setup (does away with all of those "little teeth"):
![](http://i692.photobucket.com/albums/vv282/Gen414/DSCN1587.jpg)
Now, all of those "little teeth" ahve become just a few "lugs", so have alot easier time finding their way "home", here:
Make sense?
Basically, you have ALOT more room for the engagement window...you only have 7 lugs, or "teeth" that have to engage on a faceplaed tranny, as opposed to trying to slide 50 or 60 "teeth" on a synchronized tranny into place. Now, not sure on how many actual teeth are on a synchro, but there are alot I can assure you(start counting in that pic above, and that is only @ 1/4 of a synchro, so you can imagine)
The disadvantage to this is driving it on the street. It's not recommended. Many people do, as will I, but it will take completely changing your driving habits. Due to there being no syncros, downshifting will be very difficult. You will need to "rev match", or match the rpms of the engine with the input shaft in the trans. That way everything is spinning at the same speed and it should slide right in. Here's a video showing what it takes to drive one on the street. This one is pro shifted, not facepated but you drive it exactly the same.
http://www.youtube.com/watch?v=2-MABhwPV00
Advantages are for strip only...less likely to miss gears (in fact, basically impossible at this point to miss a gear) Not saying you CAN'T, but you would really have a hard time missing a gear at this point.
Disadvantages...basically, more noise/clunking from tranny when shifting. You can get used to it (driving on the street) but if you are a "AC/heat/radio/sound deading material" type of guy, chances are faceplating is not for you.
If you are a "ripped out all AC/heat/carpet/radio/sound deadening material loud as I can get it" kind of guy, faceplating is for you.
Sweiser...make sure you get us some video when you get that MONSTER clutch and your FACEPLATED tranny installed, all from MORRIS MOTORSPORTS
.....been working so much on OTHER people's trans/stuff, need to light a fire under my *** to get me back going on my junk! Maybe a good video will help out!
Enjoy!
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Enjoy!
Enjoy!
Enjoy!
What is the difference between this and a Dog Box setup, they seem to do the same thing, but then again, I have only had a limited experaince with them? When I had my 3000GT VR4 and was messing with the Imports I knew a few that had the Dog Box Trans. It was fun to drive, but it needs a little getting use to for traffic use.
Dog Box info:
http://forums.nasioc.com/forums/showthread.php?t=665334
DM
Dog Box info:
DM
A good driver would make it faster. I'm not saying the guy in the video is a bad driver either. You pretty much have to push the clutch in almost all the way on a stock trans. With it faceplated you can just "slap" the clutch pedal with your foot just enough to disengage it and pull the next gear. It WILL go into the next gear even if the clutch isn't depressed. Once you get used to barely pushing in the clutch you will be noticeably quicker with your shifts. An adjustable master will make it even better.
Dog Box info:
DM
Dog Box info:
DM
Well, all depends...but faceplating 4 gears (5th and 6th are not faceplated, and are still synchronized) will normally run ya @ $800-$1000 all depending on a few things.
At this moment ANYTHING is possible, if your wallet is deep enough, but no, to the best of my knowledge, no one is making straight cut gears for teh T56. Now, I am not 100% on that, but am 99% positive.
There are options in getting the gears made out of a stronger alloy, the 9310, and that will set ya back @ $2500+
