Clutch Install
Old Feb 13, 2010 | 11:46 PM
game_overz28's Avatar
Default Clutch Install
I have a new Spec clutch to install.. Is their a factory shim behind the slave or do I use the one that come with the clutch??
Old Feb 14, 2010 | 12:53 AM
NVR_SPDS's Avatar
No factory shim that im aware of.
Old Feb 14, 2010 | 12:24 PM
Thanks
Old Feb 14, 2010 | 01:41 PM
Wesmanw02's Avatar
As was mentioned, no shims from the factory. The slave just attaches directly to the front plate of the trans.
Old Feb 14, 2010 | 01:54 PM
SWEET98SS's Avatar
Are you upgrading the master cylinder? If you are go adjustable. There are alot of people posting on here that are having problems with getting into gear or getting out of gear. An adustable master pretty much solves this problem. You adjust it until it slides into gear easily. If you are competent on measuring for a shim, then you should not need the adjustable master. There is a write up on here about measuring for a shim. follow the below instructions
https://ls1tech.com/forums/manual-tr...good-tech.html
Old Feb 14, 2010 | 04:07 PM
I do have a ram adjustable master.. my problem is the clutch is engaging at the top of pedal.. the clutch is slipping so i figured i need a new clutch..
Old Feb 15, 2010 | 12:35 PM
SPEC-01's Avatar
As a clutch wears the engagement point will raise relativeto pedal travel. Our kits are intended to be used with the shim provided in the package. Just unbolt the slave, install the shim and bolt the slave back in place. If you have any further questions let me know and I will be happy to assist you. Thanks!
Old Feb 15, 2010 | 01:19 PM
Thanks alot.. This is my first spec clutch..Just wanted to make sure I did it right the first time..
Old Feb 15, 2010 | 08:00 PM
I was reading on installuniversity and they said something about a factory shim.. Im needing to know if i re use it or just use the one supplied with my spec clutch??
