flywheel difference between 4.8/5.3/5.7
is there much (if any) difference betwene the smaller engine flywheels and the 5.7 ls1 ?
in particular this diameter :
the diameter is about 6.45 inch (16.3cm's)
![](http://img109.imageshack.us/img109/8996/vliegwiel571.jpg)
i'm planning on using this clutch and plate :
![](http://img109.imageshack.us/img109/8190/vliegwiel57cimbmwplaat1.jpg)
so you see , i need a bit of extra meat for the plate.
i don't feel confortable welding material on a cast flywheel do get this done, so need a different flywheel with a smaller clutchplate bas
48, 53, 57, differance, difference, differences, differnce, flywheel, flywheels, ls1, manual, stander, tranmission, transmission, work
