are my syncros bad?
Old Feb 22, 2010 | 02:12 PM
82cetuner's Avatar
Default are my syncros bad?
The transmission I put in my 82 vette is a 2002 t-56 out of a camaro with about 135k on it.
The car is a monster but once in a while under high rpm shifts when I push the clutch in the change gears at high rpms I get a grinding noise and on one occassion I tried to go in another gear and got more grinding trying to go into the next gear, I wound up having to go into 6th to keep it from grinding when I came off the clutch.
its like one of those ghost problems sometimes it happens sometimes it dont.
I also have a problem sometimes when I am sitting at a light with the clutch DEPRESSED and when the light goes green I press the clutch in and it dont want to go in first I either have to
1. depress the clutch again and then press it to get it into first or
2. just shift to second and start in it.
I am pretty sure this thing needs a rebuild. but my question is how seriouse is this? is it possbile to drive it like this for a few months? when I am not hard on the shifts it works just fine and only occasionally does it do this
Old Feb 22, 2010 | 02:22 PM
LS1vazquez's Avatar
Is there enough fluid in the transmission? It sounds like the trans might be heating up and then displaying some issues with shifting.
Old Feb 22, 2010 | 02:42 PM
Gonoma's Avatar
sounds more like a hydrolic system problem to me...you sure its bleed right?
Old Feb 22, 2010 | 06:18 PM
82cetuner's Avatar
not sure its bled right but i made a 1700 mile trip with no problems
running 90 for 4 hours strait most the time. had no issues on the trip, but like I said seems to only occure every so often when I try to launch. sometimes when I push the clutch in befor I even shift the it grinds
Old Feb 22, 2010 | 06:19 PM
82cetuner's Avatar
pretty sure the hydrolics are good, the clutch disingages after only about 10 percent of pedal movment.
Old Feb 23, 2010 | 06:43 AM
Gonoma's Avatar
might be your syncros then but wouldn't hurt to check your fluid like the guy above said and see if that fixes it
