Odd "click" noise LS7 clutch setup! HELP!
So...
I just installed a used LS7 clutch / flywheel in my camaro.
The PP, disc, and flywheel looked GREAT.
Only question i have...
When i push the clutch... there is a "click" noise.... clutch works GREAT... but now after about 20 miles of driving its literally goes "click click" when i push the clutch in... doesnt do it as the pedal rises... only as it goes down and i can feel it in the pedal...
I dont know where to even start thinking here....
Any ideas?
Any ideas?
i had the same issue with my jeep, and when i pulled the trans after just installing a brand new tranny, then i noticed that 2 of the fingers were bent and had excessive wear on them. i reused my same clutch. could u have possibly bent them when installing the tranny?
Now master cylinder does have adjustment mod, and it is adjusted to push down pretty far
