Loctite on PP bolts and flywheel...
I used the goo loctite when i installed the clutch. But noticed when i pulled them out there wasnt very much loctite on the threads at all. all seems to be smashed to the front.. Is this normal?
Thanks guys,
Erik
Thanks guys,
Erik
I always suggest the use of loctite when installing pressure-plate to flywheel and flywheel to crank bolts. High-temp (red) should be just fine. Let me know if you have any further questions. Thanks,
Thanks for the replys guys. But I was actually talking about how much stays on the threads when you install them. It seems to me more is pushed out than what stays on the threads. when i took my bolts out there was barely any on there, is that normal?
