T-56 swap
Old 04-06-2010, 08:42 AM
crazymonkey's Avatar
Default T-56 swap
I'm converting my 4L60e to a T-56. Found a 05' GTO T-56 for cheap and in good condition. Are the F-body T-56 differ then GTO? Are they interchangable? and if so is there any special i need to know?
Old 04-06-2010, 08:49 AM
85MikeTPI's Avatar
Search for "GTO" in this forum, you'll find lots of info..
Basically a direct swap, you just need to be aware of the starter/bellhousing issue, and change over the shifter offset lever from the GTO to a F-body version.
