Corvette B&M Ripper + T-56 Trans Am
Although B&M does make a Ripper shifter specifically for the LT1 Firebird/Camaro, I have came across a good deal from a friend for a B&M Ripper for 97-05 Corvette. The linkage appears to be the same between the two shifters with the only difference being the stick length. Will the Corvette Shifter install properly in a T-56 Trans Am?
B&M Ripper Shifter Camaro & Firebird
http://www.jegs.com/i/B%26amp%3BM/130/45052/10002/-1
B&M Ripper Shifter '97-'05 Corvette
http://www.jegs.com/i/B%26amp%3BM/130/45044/10002/-1
Any input is helpful.
Thanks
Edit
For anyone interested, after some research and help from the guys over at Camaroz28.com I've realized this probably won't work.
Thanks
Edit
