Couple T-56 questions...
To make a long story short, I recently traded for my Dad's Firehawk back and he had put a Rossler TH350 in it. Which is fun, and works perfect, however, I'm wanting to drive the car more, and the lack of overdrive, 4500 non-lockup, and 4.56 gears make that alittle tough. So I'm wanting to go back to a T-56 (which it was factory). I'm a newbie when it comes to 6 speed stuff. The car is a built heads/cam (ported&shaved 5.3's/MS3) car that makes good power and weighs a couple tons. What I'm wanting to know is, can I get away with a stock (low-mile) T-56 with a good RAM or LS7 clutch, or should I go with like a built t-56 and a better clutch? I won't be using sticky tires, or racing that often, maily just having fun on the street with the occasional "power display" LOL. Any suggestions would be great. Thanks.
Chris
Chris
If you get a used unit and can open it up anyway, you should think about beefing it up by upgrading the above parts.
