Tremec Magnum + Monster Stage 3
ok I have a Tremec Magnum + Monster Stage 3 Clutch for my ls swap in my Mustang.
The question i have is What master cylinder should i get for my pedal assembly?
I wanted to buy a Tick for a F-body. But i cannot see spending the money for something i am gonna have to make fit. I see they use Tilton Mc's,then i red that its a tilton MC with a 7/8 bore. so should i just buy the tick or get the tilton. I have a 87 turbo coupe pedal assembly that i am gonna modify.
And for you guys doing this swap the tremec magnum shifter location is in the factory spot on the stang using the AJE k member.
any info will be greatly appreciated
The Tick master IS a Tilton with an adapter to fit an f-body. The guys from Tick will tell you this or you can see that this is the case when you look at the pics on their website. So it would be pointless to do this. You can order this exact 7/8" Tilton master from Jegs or Summit for about $105.
