Shifter removal/trans fluid refill
Last week I ordered a MGW shifter and it should be here Tuesday I'm hoping. I'm sure the shifter removal is fairly straight forward but is there any special tips I should know?
Also, while I have the shifter out...would it be a good idea to change my transmission fluid? I have some problems getting it into 1st and reverse from a stop. To my knowledge it has never been changed and I see some people recommending to change it every 10k miles, others 30k miles, so I don't know...but I have almost 70k on mine. I have no idea where to fill it from and some say the easiest way is from the top where the shifter is so that's what I was going to do. How far should I fill it up to? I would be using the regular Dex III I guess, since I have gotten so many mixed opinions on what fluid to use. Many people seem to like the Honda ATF fluid though and some like the Mobil 1 Synthetic ATF but other say Synthetic is bad for the synchros or blocker rings so **** Idk haha
If you have the shifter out then yes fill it through there. You'll need 4qts of Dex III. For future reference the drain hole is on the passenger side and has "drain" by it. The fill hole is on the driver's side and says "fill" by it. A hand pump to fill it from underneath is the best way to do it and is really easy.
