Having problems shifting into any gear
I have a cammed 98 z28 . I just installed a Spec 3 clutch and have had an 02 Master Cylinder for a couple of months now. I take it to the track maybe once a month and drive it daily.It has 36k. Now I have to physically force it into gear and sometimes wiggle around to find the gear to shift into. I have had problems in the past getting it in reverse but now its a PITA driving it to work. Any suggestions?
Thanks in advance Gilbert
And everytime you Force it into gear you are Tearing up the teeth on your Syncro Assemblies 120 bucks a piece and your Gears, 120 Buck a piece also.
Need to stop driving it and fix it. Or you will be paying if you haven't already Trashed the tranny.
Never Force a tranny unless you want to rebuild it.
Isn't that near Houston?
I'm in Austin And If I had just the tranny and all the parts I can rebuild one in about 3 hours.
I only charge 60 Bucks, You buy the parts and I will hook you up with that.
Tom
Just a thought for a weekend Drive to save money.
Gilbert
