Spec 3+ issues
Old Jun 10, 2010 | 01:28 PM
98legendws6's Avatar
Jeremy is right. Not sure what shop you used to have it installed but if they are not a shop that more or less specializes in our cars then they wouldnt understand just how picky the clutch setup is on this car. My Spec didnt need the shim, and i know this because i measured it myself about 5 times before reinstalling the transmission. I hate to tell you this but you really need to either take the car to a shop that knows F-Bodys, Or drop the transmission yourself and take the proper measurements. If you know the measurements then there should be a more defined root cause to your issue. SUCKS i know....
Old Jun 10, 2010 | 06:34 PM
20sickss00's Avatar
yeah, i will be pulling the trans this coming week, I did not take the measurements because spec told me that it would be fine with a new flywheel and their provided shim, I guess the trans wil be coming back out this week, sucks but I'm not spending more money for another shop to do it, sucks because this will be the second time I am doing it besides the other shop. thanks guys for the help
Old Jun 11, 2010 | 12:13 PM
WKMCD's Avatar
I've got a Spec 3+ in my 427 and once broken in it's been great. I run an aluminum flywheel.
Old Jun 11, 2010 | 02:25 PM
eodmonkey's Avatar
hey what was the weight of your stage 3+ vs stock? it looks like i'm gonna have to upgrade my current and i was curious to the difference. i'll be using the alum flywheel aswell. how is the combo vs stock?
