Nightmare with hydraulics
Remoted clutch bleeder FTW!
Sounds like a bleeding issue if you have replaced all that.
My problem ended up being the clutch, my theory is that as it would heat up the pressure plate would begin to "stick" and loose tension.
Good luck!
Good luck!
