Shifter/Transmisison problem after rebuild? HELP!
Took my dads Z06 transmission apart to replace a toast 3/4 synchro, and replace the clutch. Just got the car back together. Problem is that I can't get it into reverse, and 1st, 2nd, 5th, and 6th are at the very edge of the shifting pattern. The center gears, 3rd, and 4th have a HUGE space in the center of the pattern. The shifter is also very sloppy in 3rd and 4th, moves around in the same area that it accepts it going into gear.
WTF did I screw up? lol
