Hybrid Assembly issues. HELP!
Old Jun 12, 2010 | 09:32 AM
jeeperanthony's Avatar
Default Hybrid Assembly issues. HELP!
I am reassembling the vette/F-Body hybrid, and I got the main case on the front plate and in neutral, the assembly spins fine, but when I try to shift into any gear, it locks up, almost as if its in 2 gears. Any ideas?
Old Jun 12, 2010 | 10:09 AM
85MikeTPI's Avatar
Is this using a GTO mainshaft or the SSR mainshaft?
I don't think this has anything to do with it being a hybrid, just that the shifter assembly fell off during assembly. Is this your first rebuild?
Getting the main case and front plate mated, while putting on the offset guide lever and guide pins at the same time, is probably the hardest part of the reassembly, especially if doing it for the first few times.
Old Jun 12, 2010 | 10:58 AM
thesource's Avatar
Sounds like a syncro ring is sticking. Probably the 4th gear if I had to guess. Did you put some lube on the frictions when you assemblemed it?
Old Jun 12, 2010 | 11:27 AM
I think the shift rail is falling apart. Any tricks to getting it in? and it is suppose to spin with the main case in place?
As for the frictions, what are you calling the frictions? Not too up on the lingo haha.
And using the GTO main
Old Jun 12, 2010 | 12:36 PM
thesource's Avatar
The syncro frictions (the fiber rings for the syncronizer assembly).
