3rd gear issue
Old Jun 15, 2010 | 08:38 PM
260B4U's Avatar
Default 3rd gear issue
so when i'm driving in 3rd at low speed it just drops out of gear into netural it never grinds or miss shifts which is why this is odd never a problem until saterday night i pull out and rip from 1st to 2nd and when i try to go to 3rd its stuck in 2nd and so i had to push it out and then it wouldnt go into any gear it check the clutch fluid its black so i flush it out and the clutch and tranny work fine except for the weird 3rd gear thing
Old Jun 15, 2010 | 09:00 PM
thesource's Avatar
I've had this issue happen before. Chances are you have wear on the 3-4 shift fork pads and the fork is not pushing the slider over the 3rd gear completely.
