Reverse lockout seems stuck on
I recently changed brakes all around, wondering if I may have messed something up but I don't believe i did.
On a side note, i was having some electrical problems with my oil pressure sender which seemed to go away once i checked connections and wiggled wires a bit.
I am wondering if this is an electric problem or something else. Any ideas?
I was having problems with my oil pressure gauge spiking all over the place (obviously electrical) and I can't figure out what the issue was.
Im guessing something related to that blew the fuse. For some reason, it works perfectly fine now I cant find any loose or burnt wires in the quick inspection i gave. Anyone have any ideas where i can look for the problem.
