More props for the Tick Master
Old 07-11-2010, 04:50 PM
TTA1437's Avatar
Default More props for the Tick Master
Installed it yesterday. The install went great. Not hard at all.
Pre Bleed the master and bleed the slave using the pump then pump hold, crack the bleeder and close method. Took a few times and got it.
My pedal rests almost fractionally level with the brake pedal.
Drives soooo much better. Much more fluid and crisp.
Well worth the investment since the stock master has a roll pin that holds the psi line to the slave and popped out twice.
It made the Spec stand 3+ much nicer. When I installed this clutch I didnt see the posts about measuring for a shim but used it anyway hopefully im good to go. What do you guys from Spec or Tick think?
Old 07-11-2010, 05:24 PM
TTA1437's Avatar
I do have a question. Does the black rubber cup that is inside the reservoir need to stay or can it go? Right now I have it in there.
Thanks
