What connects the shifter to the rear transaxle on a C5 Vette?
Old 07-13-2010, 08:54 PM
LS1-450's Avatar
Default What connects the shifter to the rear transaxle on a C5 Vette?
As noted, how does the shifter attach to the transaxle? Is there a single straight shaft that runs from the shifter to the transaxle shift pin? A pic or even a hand sketch would be very helpful. Need to know for a possible swap solution. Thank-you
Old 07-13-2010, 09:12 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
Yes, a long rod attatches to the the shifter box on one end and to the shift rail that extends out the front of the transmission on the other end.
Old 07-13-2010, 09:25 PM
LS1-450's Avatar
Wow! That was quick. Thanks so much. That's what I was hoping for. Thanks again, really clears things up for me on the swap optional transaxles, C5 FTW.
Old 07-13-2010, 09:54 PM
LS1TECH Sponsor
No problem, I just logged onto alldata and snagged that picture.
