3rd gear grind question
Old Jul 18, 2010 | 12:11 PM
CHRIZ28's Avatar
Default 3rd gear grind question
Bought a 12k mile t-56 from a member here to replace the A3 setup that was in the car. Had a local hot rod shop install everything. All works good, clutch is smooth, every shift is good, except 3rd. It grinds like crazy and won't let you in it. If you put it in third then start the car, it's there, but no way you can get it driving. Just wondering if there's anyway this could be something that could be caused by installation error, or shifter problem or what. I'm using a stock hurst shifter, and like I said every other gear it works perfect in. Member said it worked perfect when he pulled it. Just wondering what you all think. I'm fairly new to the t-56 world. Thanks.
Chris
Old Jul 18, 2010 | 07:04 PM
RedRocketZ28's Avatar
Sounds like a rebuild is needed. Mine is doing the same thing only in 4th.
Old Jul 19, 2010 | 08:22 AM
CHRIZ28's Avatar
Yea, I figure it's gotta come out. Its just the guy I bought it off of says it worked perfect when he pulled it. Just can't see the 3rd gear synchro going out just sitting, I dunno. Didn't know if something could happen while it was sitting or not.
Chris
Old Jul 19, 2010 | 06:16 PM
BAD APPLE SS's Avatar
probably a bent 3-4 shift fork. they're aluminum stock, replace it with a steel one. pretty common thing.
Old Jul 19, 2010 | 09:18 PM
V8MUSLE's Avatar
ive gotten mine moving in third before. prolly a little rough on the clutch, but it drove off.
