t5 questions
t5 questions
i have a first gen sbc and am wanting to mock a T5 tranny behind it.. What particular tranny will I need and what will be needed to be done for it to fit. I hear that they dont hold up to much power and Im looking to have about 300-350 tq. Any info is greatly appreciated. Thanks
The problem with the Camaro T5 is that they are rotated over a little bit so it requires some creative fabricating or possibly buy a crossmember design for it. You want to look for a 1988-1992 V8 F body T5.
into what car?
If you go with a V8 88-92 F-body T5,
for mechanical clutch release, get an 83 Camaro bellhousing (tilted 17 degrees) and for hydraulic, you could go 84-92 Camaro bellhousing (tilted also.)
Or Lakewood makes scattershields for either option that have both the tilted and straight up trans. patterns.
All those have a fork that points down a little bit (7:30 instead of 9:00)
its going into a s13 240sx.. im debating between the t5 and th350 because i want some straight line fun but also be able to go sideways.. ive been thinkin about doing a th350 with a manual valve body or the t5
