spec clutch is here, as is another question
Old Jan 21, 2004 | 07:05 PM
KALEL's Avatar
Talking spec clutch is here, as is another question
i got my clutch today and it came with a piece of paper that said i should resurface my stock flywheel. i plan on putting the clutch in myself this weekend hopefully. can i resurface the clutch and if so how do i got about doing it??
Old Jan 21, 2004 | 10:18 PM
onefynryd's Avatar
Take it to a local shop, they can resurface it for you. Probably cost around $20 or so. Best bet would be to check out SLP's clearance section, New OEM flywheel for $50
Old Jan 22, 2004 | 01:11 AM
Cal's Avatar
Cal
Yeah you should always resurface the flywheel when you do a clutch replacement. If you don't, it will chatter like hell, ask me how I know! Most shops can get it back to you in a hour if you let them know you're in a hurry. For the last one I did, they only had to take off 10 thousandths to clean it up.
