looking for some help
Old Aug 18, 2010 | 07:39 AM
firemech21's Avatar
Default looking for some help
I just put a new stage 2 tranny, spec clutch, master cylinder, throwout bearing, slave cylinder, and the rest of the hydraulic parts in my car. Its a 99 T/A. Now when i shift into revers (running) you have to force it into gear, when the motor is off but the key is on it shifts fine into reverse. The problem some times happens with 1st as well. I am about 250 mi into break in, but i dont want to screw anything up. So what else should i check into?? I have bleed, re-bleed, and re-bleed the hydraulics. I put about 2 quarts of fluid through the system. I also put the shim behind the slave cylinder (spec included with the clutch kit), i have read that some people take the spring off the slave cylinder but i kept mine on there. Any help would be great especially after blowing all this cash on a new drive train.
Old Aug 18, 2010 | 07:52 AM
85MikeTPI's Avatar
Check for clutch drag, and if there's none, just be patient and wait for the break-in period and change the fluid...
Old Aug 18, 2010 | 09:36 AM
firemech21's Avatar
oh i also have a new flywheel too. How do i check for clutch drag on this setup? Also what can i do to adjust the engagement point for the pedal, besides buy an adjustable master cylinder.
Old Aug 18, 2010 | 09:59 AM
SPEC-01's Avatar
Put the car in first gear, with the pedal depressed, then rev the motor. Does the car creep forward or not? How are you bleeding the system? Have you used a Mighty-Vac? Let me know and I will be happy to assist you further. Thanks,
Old Aug 18, 2010 | 11:14 AM
firemech21's Avatar
So i just went out front and tried 1st gear. When i press in the clutch and rev it above 4, it barely creeps 2 inches then stops. I have bleed the crap out of the hydraulics too. The guy who did the trans says the clutch isnt going in far enough to release the trans from the motor, is this true? What can i do to fix this without having to blow a bunch more cash, because my funding for this project is spent...
Old Aug 18, 2010 | 12:48 PM
SPEC-01's Avatar
Have you used a Mighty-Vac to bleed the system? If not, from experience, I have seen people bleed these systems with more "traditional" methods and not get all the air out. I suggest giving it a shot. Let me know if you see a change when doing this. Thanks!
Old Aug 19, 2010 | 11:23 AM
firemech21's Avatar
alright so i put in an adjustable master cylinder and rebleed the system, seems to be good now. it goes into all gears fine and no more rolling at high revs in 1st gear with the clutch in.
Old Aug 19, 2010 | 12:40 PM
SPEC-01's Avatar
Good deal! Let me know if you need anything else. Thanks,
