Engagment
In any case. Tonight when cranking it will only crank as if its in gear. It jumped when I turned the key.. I pumped the clutch a few times and stood on it in the floor and it cranked. I do have the stock clutch master cyl on the car. I have a tick in the trunk that I need to get installed. Im hoping thats the problem. Oh yeah after cranking it i drove it and all was fine in 3rd and 4th. When I down shifted to 2nd or 1st it would buck a lot had to sorta ride the clutch in those gears to calm it down.
Anyone have any insight on what this could be?
Just occasionally it's a failed/defective diaphragm spring in the pressure plate, but you rule out the hydraulics before moving into that area.
