clutch
Old Jan 26, 2004 | 01:02 PM
LenoZ28's Avatar
Default clutch
How can you tell that you clutch is slipping?
Old Jan 26, 2004 | 01:12 PM
Bugsquawsher's Avatar
Whats it doing?
Do you take it to the track?
Its pretty easy to notice a slipping clutch.
If you rev up and dump the clutch do the tires spin?
Old Jan 26, 2004 | 01:41 PM
SSCamaro99_3's Avatar
Saturday, 5000 rpms, 2nd gear, and 30 mph. Slipping clutch.
Old Jan 26, 2004 | 02:47 PM
LenoZ28's Avatar
Default Clutch
i DUMP IT AT ABOUT 1500 ON THE STREET AND I SPIN LIKE A MOTHER.
oN THE TRACK WITH NITTOS AT 3000 I STILL SPIN THEM.
Old Jan 26, 2004 | 04:12 PM
oldskoolz's Avatar
when it begins to slip the pedal should push in a lot easier and when the clutch does eventually go the pedal will go straight to the floor and there will be no tension on it whatsoever.
Old Jan 26, 2004 | 07:47 PM
Orange99Z's Avatar
Your RPM's go higher but the tires aren't spinning and you're not going anywhere. Then it will start to stink, kinda like hot brakes, but worse.
Old Jan 27, 2004 | 09:22 AM
Soft pedal, and the above problem twice. I did manage to still smoke a 93 Cobra when it happened.
