Backup/Lockout Wiring help w/ T56 Swap!
Hey guys,
I have a 93' F-car and I swapped to M6 from A4, I am almost done but I need some wiring help.
How/where do I wire in the lockout and backup sensors from on the A4 pigtail? Do i need to come all the way from the PCM?
Overview of the A4 harness on my car:
1- 4 pin connector
1- VSS switch
1- 4 pin connector
1- VSS switch
my 00' had a 6 pin connector on the shifter, not sure on lt1's
for the reverse lockout I currently have mine wired to my brake light switch and grounded to the airbag thingy under the console. I'll be doing it correctly soon, search for "the merv" or something along those lines, he did a writeup on which wire to trace back to the PCM. He used one of the unused wires from the A4 and pinned it to the stock location on the PCM so with the M6 tune it will work just as if stock.
