Need Help.
Old Oct 11, 2010 | 06:43 PM
sean1997ws6's Avatar
Ok, bleed it with a mighty vac and got very few tiny air bubbles out and still have the same problem. I am now guessing that the zoom clutch must require a shim for the slave. Thats the only thing left as I already replaced the slave and master.
Old Oct 11, 2010 | 09:00 PM
thanks crain, Ill give that a shot. What is a nice strong slave to get if indeed i need to get a new one and shim it?
Old Oct 13, 2010 | 08:50 PM
Ok, If this helps any at all. I bought a mityvac and bleed it and still have the same problem. The pedal feels a little harder but the first 2-3 inches has zero resistance at all and then it will catch. It will only go into gear if I push the clutch all the way to the floor as hard as I can and it will still move forward a bit.
Old Oct 17, 2010 | 04:33 PM
Any one? Does this sounds like a slave issue or maybe something a Tick Master would take care of. I hate throwing a lot of money around. Any experiance would be great. Thanks.
Old Oct 17, 2010 | 04:40 PM
Originally Posted by crainholio
Did you re-bleed with a helper as I posted above?
Yes, I did it a few times. Got a few small bubbles but nothing more after the first time.
Old Oct 17, 2010 | 04:42 PM
the thing that gets me is that when I installed the Zoom kit with the Zoom slave, I drove it from Maryland to North Carolina that night with no shifting issues at all. Then the Zoom slave was leaking and this problem developed. Now I have replaced the slave and Master with the same issues.
Old Oct 17, 2010 | 05:09 PM
No sorry I was talking about leaving the mityvac on for a bit. I have bled the old fashion way with my dad a ton before I bought the mityvac. I am just wondering if the Zoom slave was a bit bigger and the GM slave might need to be shimmed.
Old Oct 17, 2010 | 05:12 PM
so Open the bleeder while depressing the clutch?
Old Oct 17, 2010 | 05:18 PM
ok, Ill give that a shot.
Old Oct 18, 2010 | 08:55 PM
when we installed the clutch we hit the PP bolts with a gun, what are they supposed to be TQ at and will it cause issues?
Old Oct 19, 2010 | 03:20 AM
crainholio's Avatar
Wish you'd posted that earlier so I could have found something more productive to do. Go RTFM.
Old Oct 19, 2010 | 08:56 PM
  #32
Whats RTFM?
Old Oct 20, 2010 | 05:41 PM
  #33
crainholio's Avatar
Whats RTFM?
Let me Google that for you:
http://lmgtfy.com/?q=rtfm
Old Oct 20, 2010 | 09:05 PM
  #34
Thats what I thought but I just wanted to see if you were really the *** that I thought you were. Sorry to waste the however many mins of your life (that I am sure are so precious). I blew the clutch 500miles from my house and got a kit from the adavnce by my dad's house. Had 2 days to order and install the clutch so that I could get back to Camp Lejeune before my leave ran out. We can't call in sick in the Marines because we blew a clutch. So yea we tried to use everything we could (Coordless impact) to get it done as fast as possible and I didnt think that those had suck touchy TQ specs. But don't let me waste any more of your time. Thanks, Sean
Old Oct 28, 2010 | 09:53 AM
  #35
crainholio's Avatar
Way back ago, I had an E-7 walk by the lift at the post auto craft shop while I was thrashing my car back together before they closed. He said something to the effect: "Hey bonehead, you're screwing up here here and here" and walked off. Turned out he was right.
Sorry if your feelings are hurt.
Old Oct 28, 2010 | 08:06 PM
  #36
You didn't hurt my feelings. I have been in the Marines for 8 years and it would take a lot to hurt my feelings. I was simply asking a question. I am on here for help not for someone to tell me to read the ******* manual. It was an off the wall question, and I have put together that that is not the problem. If it was I would have never been able to drive it back. It was fine until the zoom slave started leaking.
