*HELP* Grinds in all gears PICS INSIDE
Sweet, yes it is the same size and brand master that everyone uses. Wilwood 3/4".
TA-BUD, yes it is a new slave. I am using the one from an F-body cause I've heard the only difference between the GTO and the F-body one is a different fitting. And the fittings need to be swapped out anyway on this swap...
This is awesome! Thanks so much!
Clutch in.
Start the car and leave the clutch in.
Put it in first, and it goes right in.
I did this several different times and all results are the same.
Clutch in.
Start the car and release clutch.
Then clutch in and try to put it in first and it grinds.
So basically once the input shaft gets spun up the synchro's can't get it spun back down enough to put it in gear.
I'm going to try some different scenarios of gear changes, but I think it's pretty conclusive at this point.
I never knew the synchro's did so much...
<3 you Wesmanw02!
(nohomo)
Here's a definitive test to see what going on:
1. Hold the clutch to the floor, engine off, transmission in neutral.
2. Start the car.
3. With the clutch still held to the floor, engage 1st gear.
If it grinds, your clutch is dragging.
If it goes in easily, its the synchros in the transmission that are causing your problem.
2. Start the car.
Clutch in.
Clutch in.
<3 you Wesmanw02!
(nohomo)
hey man i am new to this whole forum deal. but i have a 98 ls1 car and when you shift it from first to second it goes fine but when you realease the clutch it jumps out ofgear and grinds. it has alaso kind of started to grind when down shifting into 1st car is a good car but has been beat on you think just time to go thru the trans? 105000 on the odo
Hell I don't know.
I'm new to this stuff...
I should update this. Sorry it has languished.
www.texasdrivetrainperformance.com
^seriously...
The best transmission rebuild shop IN THE WORLD.
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/19245c34.jpg)
Apparently my trans was really bad. Like he hasn't seen one this bad in a while.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Required a new first gear.
3rd gear outer ring
4th gear outer ring
1-2 outer ring
1-2 inner ring
Example A
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/638dad7f.jpg)
Said and done, I would not have done this any other way. TDP was supremely knowledgeable, beyond helpful, and bent over backwards to get me back out the door quick.
I can't recommend them any higher. Totally surpassed any expectations I had for them.
Back home...
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/a122c29b.jpg)
Under the car...
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/aa2cf43a.jpg)
Finally on the road...
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/1539ccae.jpg)
![](http://i660.photobucket.com/albums/uu322/__kirk__/LS1/b8356934.jpg)
So awesome!
TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP TDP
^seriously...
3rd gear outer ring
4th gear outer ring
1-2 outer ring
1-2 inner ring
Example A
Back home...
Under the car...
So awesome!
Clutch in.
Clutch in.
<3 you Wesmanw02!
(nohomo)
Good to hear you got the trans rebuilt and you got it on the road
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
