Replaced master & slave
Old Sep 24, 2010 | 07:29 PM
airattack111's Avatar
Default Replaced master & slave
I replaced my master cylinder about a month ago with an 01+ MC with drill mod, and yesterday replaced my slave with a new GM slave.
I starting bleeding the **** out of the clutch today with not much success. Clutch engages fairly close to the floor, hard to get into 1st gear after depressing clutch, "car seems want to jump forward slightly when going into first", and it engages very quickly.
These problems are nothing new, I've been having them for a while. I changed the master, I changed the slave, I bled the system (pump pedal, hold down pedal, crack bleeder, keep resevoir full). What's the deal?
Old Sep 25, 2010 | 07:32 AM
therealcreeper's Avatar
squeeze the line from the reservoir to master a few times, flick the master to slave line, keep bleeding and bleeding, try mightyvac
it's a PIA to get the air out of these systems. I have better luck completely bleeding the master first before attaching it to the slave, and then bleeding that
Old Sep 25, 2010 | 08:16 AM
rabiddog's Avatar
did you check your clutch when you replaced the slave??? It might be the problem.
Old Sep 25, 2010 | 07:18 PM
clutch / clutch plate is fine
