clutch pressure problems
Old Sep 25, 2010 | 11:20 AM
devilsalmostfree's Avatar
Default clutch pressure problems
i replaced the engine in my 95 3.4 camaro a while back, got the engine going. transmission wouldnt go into gear, clutch had no pressure to it, friend felt a pop as he was pumping the pedal. so i replaced the clutch master cylinder, & still no pressure in the clutch, so then i replaced the slave cylinder, still nothing! so last weekend, we tried bleeding the system, although it states in the haynes manual that u cant bleed these clutch systems. what do u all think the problem may be, any advise would be great, thanks in advance for ur help!
