differences in t56?
what are the differences in the t56 of the 98-02 vs the 04-06 6.0 gto's?
are the lengths of both the same ?
where the torque are bolts onto the trans in the same location?
is where the crossmember bolts the same?
any other info would be great
- Gearset: MN12 (GTO) with 2.97:1 first vs MM6 (fbody) with 2.66:1 first
- Synchro design: triple/double cone (GTO?) vs double/single (fbody)
- Starter/bellhousing size/area: Can swap starters or clearance bellhousing
- Shifter and shifter-offset lever: can swap between the 2 easily
Everything else externally is the same.
The aftermarket GM T56 is a different animal, meant as an upgrade for the T5 3rdgen Fbody's to a T56 using the same clutch/bellhousing/shifter. You don't want to deal with an AM version unless you have a pre-92 manual transmission vehicle, and even then it may not be the best choice.
oh an are the after market tremec t56's the same as the the 98-02 and 04-06 gto the location of crossmember, torque arm, and the length of it?
and how can u tell the difference between the camaro t56 and the gto? is there a different serial number on the housing ? any thing else ?
also i heard u can change the cup to fit a fbody shifter so the shifter sits more foware towards the bellhousing..but changing the cup, do u change just the shirter or the tail shaft, or?
i have 3.73 in the rear and the mn12 3-4 gear suppost to be a big jump, will it bogg my motor(ls3) or with the 3.73 be fine
