New clutch problems
My question is, I bought the slave cylinder used with about 10k on it from a board member. When I got it, it had a thin spacer (about .040) behind it which I did not install. Was I supposed to put this in?? I'm about at my wits end here and actually consittering buying a stock clutch to see if it fixes the problem.
Re'
Re'
Re'
Re'
Anybody got any other ideas before I pull the trans to inspect it???
Re'
The LS1 and LS7 clutches are not completely identical. The TOB on the LS7 slave sits a fraction of an inch closer to the PP fingers than on an LS1 slave.
And not every slave is exactly the same. You should measure for a shim with every clutch install just to be sure. That 3/4" travel you have before the pedal gets solid is the distance the TOB is traveling before it touches the PP fingers. A shim will put the TOB closer to the fingers and shorten that distance. The shorter the gap, the longer the throw you'll have on the clutch.
