Bench bleed?
Old Oct 17, 2010 | 05:31 PM
airattack111's Avatar
Default Bench bleed?
I'm looking into how to bench bleed my clutch master cylinder. I don't have a slave cylinder to connect to it. is there another way to do this without the slave cylinder connect line?
Thanks.
Old Oct 19, 2010 | 09:26 PM
Circa307's Avatar
bump trying to find out myself
Old Oct 19, 2010 | 10:28 PM
RARON455's Avatar
What I did was left my line that plugs into the slave cylinder attatched to the master, Then I took a bottle of brake fluid, cut the top off, I then inserted a small screwdriver into the end of the fluid line (pushing that little plate in the end open), I then submerged it into the bottle.. Once in I made sure that it never came out while I pushed the master cylinder in and out adding fluid to the reservoir when low until I seen that it was constantly pumping fluid. Just my way sure there are others.
Old Oct 20, 2010 | 07:40 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Do yourself a favor and do NOT bench bleed. NO NEED.
Simply install the Clutch master and get all the hardware connected. Gravity Bleed the system, NO pumping, and I have done over a dozen this way. Just need the front end on jack stands and as long as you have a helper you can get it perfectly bled everytime.
