Pilot bushing removal
Anyway, if you pump a bunch of grease inside the pilot bearing hole, then find a wooden dowel rod that just fits through the hole, you can tap on the dowel rod and the pressurized grease will push the bushing out.
I had no luck with some pullers. I did use a Slide hammer with the Hook attatchment and since I was replacing, I was not afraid of damaging the bearing on the way out. Most times it needs replacing anyways and its cheap.
The part number from autozone is 27128. Be warned, the deposit for this tool is quite high. $160 I think... Put it on a credit card so when you return it, the credit goes right back to the card like nothing ever happened.
J
Thats why, as crappy as Autozone is, their rental program is so great.
J.
J
