Cannot get out of gear at WOT.
I have a problem and I am not sure if it is the clutch or trans. When I am going WOT into high rpm's, I try to shift and it will not get out of gear to go to the next one. I have to wait for the rpm's to drop down to get it to go. It works great at 1/4 and 1/2 even 3/4 throttle. Even bringing it up to 5500 at half throttle and then shifting is fine. Its just when going WOT that it won't let me out of the gear when its time to shift. I have heard that dual friction clutches have this problem so that might be a possibility? Any thoughts?
Car specs are:
tick master
centerforce dual friction
4.11's in the rear.
motor has cheatr v.3 cam and stock ls6 heads with full boltons and makes 370/370 if that matters.
thanks!
Thanks!
EDIT: This was on my Cobra, but it's the same design in theory.
