Spec 3
Old Dec 12, 2010 | 05:02 PM
RNation0001's Avatar
Default Spec 3
Will a spec 3 hold 600 to 650 hp? In the process of building a turbo ls1
Old Dec 13, 2010 | 11:49 AM
SPEC-01's Avatar
The kit is rated to handle 832lb.-ft at the crank so you should be fine as long as you are within that rating. Just make sure that you seat the clutch properly (break-in), use a flywheel that it flat, and make sure all the parts are clean and you should be good to go. Let me know if you have any further questions and I will be happy to assist you further. Thanks,
