LS7 clutch question
Old Dec 23, 2010 | 12:24 PM
  #41
TDP's Avatar
TDP
Originally Posted by Scoggin Dickey
30-40% have engagement issues? Seriously? Someone isn't installing something correctly, end of story.
Maybe I just had bad luck with them and it was enough to leave a bad taste. I don't think anyone has actually measured and physically tested anything to compare. If you have, then please share.. Thats exactly why I'm designing a fixture to do so. It will clear up any and all disputes. It will for sure tell me if it was just bad luck that I kept getting bad LS7 clutches.
Improper installation?!? Give me a break. A blithering idiot could install a clutch. It's not that hard to do.. I'm not BS'ing you, there were way too many times that I installed an LS7 kit, then had to get it warrantied out for a new one. Other times it just needed a .125in shim. Every time I got a replacement LS7 kit, it did indeed work. So hopefully you see where I'm coming from.
Bad luck...maybe? There is no way to tell until it is actually measured. The specifications that I plan to measure/compare are slave height, slave travel, pressure plate height (both installed and un-installed). Pressure plate travel, and the engagement/disengagement point within this travel. I'm going to compare every disc, pressure plate and slave on the market then post up the results here. I think it would be quite interesting...
Old Dec 27, 2010 | 08:07 PM
  #42
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've put two in two different cars of mine and never used a shim. One was a car that put down 475 on motor and then it had a 150 shot on top of that. Many highway runs and numerous runs at the track and I never experienced any slippage. The second is my DD and again no shim was used and I have yet to have an issue after almost 20K miles
Old Dec 28, 2010 | 11:21 AM
  #43
CaliboyTA's Avatar
well when i bought my ls7 clutch i was told i didnt need to shim the clutch and this was being told from 2 prominent lsx shops. few years later im having issue with my ls7 clutch and the 2 same shop told me i should've shimmed it. i dont think anybody knows what to do with the ls7 clutch
Old Dec 28, 2010 | 11:58 AM
  #44
SIC LSX's Avatar
u put it in and go what i did 40,000+ miles ago lol
Old Dec 28, 2010 | 08:16 PM
  #45
00firehawk's Avatar
Talking
Well, I just finished installing the LS7 clutch I started this thread with. I already had a shim from the SPEC Stage 2+ that was already in it. Installed it with that shim and it works fine. The only thing I don't like is that the pedal is really low. I am doing another shim tomm to see how much I can get the pedal to raise up. I will let y'all know hopefully tomm what I used and the outcome! Outside of the low pedal it works great with 447whp!
Old Dec 28, 2010 | 08:19 PM
  #46
SIC LSX's Avatar
Dude Wtf do not put another shim in it. Its self adjusting it will work its way up with break in. But if you wanna waste your time go for it. Ive installed around 12 of them no shims and no problems.
Old Dec 29, 2010 | 02:10 AM
  #47
Daryn's Avatar
Formerly darynC-10/23/10
i had futral put mine in , no spacer was used
Old Dec 29, 2010 | 08:31 AM
  #48
disc0monkey's Avatar
yeah i wouldnt bother putting another shim. one may be good to not let it ratchet as much but i wouldnt take the trans out just to add one.
Old Dec 30, 2010 | 10:26 AM
  #49
ls1m6nichols's Avatar
Default ls7
is this a good price and dhttp://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=pkc6ls7clutchk itoes it come with everything??
Old Dec 31, 2010 | 07:28 PM
  #50
Z28/2002's Avatar
Katech has them for $399 right now with the steel flywheel
Old Jan 8, 2011 | 03:37 PM
  #51
00firehawk's Avatar
Decided to just leave it be with the one shim. Like I said before it's only temp. until I complete my new build which will need a twin disc..... Thanks for all the input!!
