Cracked my tranny neck housing by shifter what to do
Old 01-19-2011 | 07:48 PM
99nbmbird650's Avatar
Default Cracked my tranny neck housing by shifter what to do
What can I do, it's cracked where the neck of the tranny comes up to the shifter i was tightning a shifter bolt an that happend any one please any advice will hep.
Old 01-19-2011 | 07:55 PM
85MikeTPI's Avatar
You can try JBweld as a temp fix, but you should think about repairing (Alum TIG weld) or replacing the tail housing at some point. Fluid does splash in that area, so if it's not sealed, it will leak.
