My first T-56 rebuild is done.
think a 6 ton press would work? i have a 1 car garage so room is ummm.... LIMITED!!!
http://www.harborfreight.com/cpi/cta...temnumber=4711
The problems with that press are
1) its not tall enough,
2) the two spanner Beams at the bottom that you can slide up and down are not wide enough to get some of the Gears Between them.
I got the 20 ton.
More power than I needed by far, but its just big enough to get all the gears inbetween.
I got the 20 ton.
